Ok , i just put in the carrier after rebuilding the trac loc and putting in 3.73 gears, set the backlash to .009 but with a buddy holding the other wheel the opposite wheel spins with it. We treid it on his 90 lx with a working trac loc and i am able to hold 1 wheel while he spins the other. Now im assuming i putting to much shim in the traction loc i guess right? I put .045 on both sides, is it ok to use like a .030???? Cause i was told to use the same size stock shims if not bigger, so what kinda shims did all you use?
