Calling all Predator owners with auto trans...
jeffnoel
1,638
Clovis, CA
Mine just arrived and my 02 is an automatic so I'm looking for trans settings that work well to get rid of the slop when shifting. A trans cooler is on the way to so no need telling me to get one.
I used to have a Predator.
Torque Modulation: Off or 0%. That means don't pull back timing to lower the torque during the shift. Just say no to granny-friendly shifts.
Part Throttle Shift Pressure: I think I had the 1-2 at 35, 2-3 at 25 and the 3-4 at 10. You might start there and adjust to your taste.
WOT Shift Pressure: I think I had those around 100. I like 2nd and 3rd gear scratches.
WOT Shift RPM: I ended up with 5750, 5600 and 5600. That was track tested though.
Anything else?
Anything else?
about where i have it but i left the 3-4 shifts alone oh and with 4.10 gears i set my 1-2 at 5,200 rpm
Sorry, I read ghoststang's post wrong.
It seems that in part throttle shifts it is not crisp like it is in WOT, especially 3-4, but I am afraid to set it too stiff because I hear overdrive is pretty weak in the 4R70W & I am scared to death of killing it.
Will your part throttle shift settings be pretty crisp & safe for the transmission?
I can PM you my Predator transmission settings later if you wouldn't mind telling me what you would change.
Can anyone post a link to some credible info on this "weak OD band" thing? Everyone says don't shift hard into 4th. I have yet to see a reason why.
Like I said, I had my part throttle shift pressures up high. Too high that it was too harsh. I don't think you have anything to worry about. Our transmission was designed to handle hard shifts at WOT. It will handle firm shifts at part throttle without a problem.
Here is the thread that scared me about OD:
http://www.corral.net/forums/showthread.php?t=805870
It involved some personal experience from people, you just have to filter some bullcrap.
I usually never turn off overdrive because my engine revs pretty high at 40-45 due to the 4.10 gears, and I am nervous about cooking my transmission (no cooler yet but very soon). Maybe I should turn off overdrive except the highway? Does everybody with autos do this?
That guy's sig shows he has a Fox. It won't have a 4r70w. Did his have one?
I remember seeing something on TCCOA about a weak OD band, whatever that is. But it applied to AODs, not 4r70ws. Somehow I think weakness this got applied to all Mustang automatic transmissions and the misinformation has spread like wildfire.
Anything else?
+1
Leave the 3-4's alone.
hmmmm.. interesting but either way when i race i leave O/D off i also leave it off when driving on the streets. The only time i use it is on the highway so that is why i just left it alone and didnt firm up the shift on the 3-4 shift
