Cam And Rpms??
I doubt it's the cam but? Need more info, trans type, running fuel pressure? Any codes?
I think you're just like jrichker...
He has all his tech answers saved as a quick reference that he can simply link to should the situation call for it.
In your case: "Need more info, trans type, running fuel pressure? Any codes?"
I call the above your Karthief white paper...
And....
What does the transmission have to do with the engine nosing over at 5200 RPM?
I've driven a GT40P combo with a b303 cam and can remember that combo would love to rev to the moon.
How was the cam installed? Straight up or advanced?
There's so much it could be that most of these will be guesses.
And....
Alas, to use my name in the same sentence as jrichker raises my ego far above my abilities, I felt the need for more info to give the more experienced (like yourself) a better chance to offer good advice.
And I have no idea if/how a transmission would effect his problem, if I knew it would cause you to respond I would ask more often :jester:
aod tran 3500 edge racing non lock up converter 373 gear and no I don't have it tuned yet and skock injectors and pump im getting ready to put a 340lph pump in and 30# injectors and 75mm t/b 80mm mass air im just rounding up part now I have the pump so I still need injectors mass air and throttle body oh and the car is black hahaha
Reactions: General karthief
When I read up on pumps, I chose a 190 lph for my 347. You shouldnt go any bigger than that. If you havent installed the giant pump, I would sell it or return it and get a Walbro 190.
Not the the B cam is know for aggressive lobes, but, I'm wondering what valve springs you are running?
float/bounce?
I believe the Bcam wants ~120lbs seat ~295lbs open...
I think the original/older GT40x heads typically have 80-90lbs on the seat, and doubt that relates to 295 open.
I would pull a spring and check it out before I went much further down the rabbit hole.
Reactions: RangerJoe
I wonder what the OP means when he says it's falling off. Yeah, I think drop off beyond 5200 should be expected.
But, if it is falling off more quickly than it should, I agree then the injectors and pump are likely candidates.
