cam choice?
  • Thread starter Thread starter blkstangman88
  • Start date Start date Apr 19, 2005
blkstangman88
646
  • Apr 19, 2005
B, E, F, or X cam from 50resto.com, i basicly want the best one, doesnt matter if i have rough idle, but im more worried about valve and piston clearance.???
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 19, 2005
  • Apr 19, 2005
None of the above! Alphabet cams are old news. Go find yourself a nice dual pattern grind through CompCams or another one of the more popular companies and you'll be 10xhappier with the results.
281pony
2,681
Oly, WA
Apr 19, 2005
  • Apr 19, 2005
really could have provided more information.
i believe an e-cam is the biggest youll be able to get with stock internals, possibly an f-cam. f-cam is too much for stock valve springs, e-cam cuts it close but will work.
i called comp cams and got a "custom" cam that was a popular grind. has the idle i wanted, good drivability, and hits hard just over normal driving rpm's.
T
TbonesBlack92GT
25
  • Apr 19, 2005
I am very satisfied with the Trick Flow Stage 1 cam. It has a sweet sounding lopey idle plus generates decent vacuum (11.5 inches at 800 rpm).
It pulls real hard from 3200 to 6200+. Specs are 221/225 @ .050 duration, .499/510 @ .050 lift and 112 degrees L.S. Plus at only $140 thru Summit (P.N. TFS-51402000) its a real bargain.
I am running Windsor Jrs. (milled .020) and during the rebuild I checked piston-to-valve clearance (using clay) and have plenty.
It works great with my combo of 3.55 gears, off-road x-pipe, Long BBK headers, Mean Streak mufflers, rpm intake and 650 double-pumper w/1" 4-hole spacer (5-spd).
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Apr 19, 2005
  • Apr 19, 2005
trickflow stage 1 , summits got them for 139
C
CJMcLean
120
Houston, TX, USA
Apr 19, 2005
  • Apr 19, 2005
Ditto for the Trick Flow Stage 1 camshaft. It's a good stick for the money, and is a good match to a slightly modded motor.
T
thompsonsd
144
Southern Maryland
Apr 19, 2005
  • Apr 19, 2005
I have the Comp Extreme Energy 35-328-8 cam and I love it, but it might damage a stock engine... think springs, hardened push rods and a new heads if you want a bigger cam.
blkstangman88
646
  • Apr 19, 2005
sweet, from the sounds of it ill get my self a trick flow cam through summit...thanx
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Apr 19, 2005
  • Apr 19, 2005
Stock heads and stage one cam...you will not be very pleased with your gains/time spent/money spent. Save for heads and keep the stock cam...all that work for MAYBE 10hp.
84blkstang
544
Springfield MO
Apr 19, 2005
#10
  • Apr 19, 2005
  • #10
I would go with the Comp Cams Xe-258, 264, or 270 which is what i have. According to Michael Yount (AKA CAR GOD) " CompCams Xtreme Energy line of cams are the only ones worth buying off the shelf in my opinion. They are far superior to most other bump sticks out there. You see, one of the most important specs about a cam you can't get much info on - that's the lobe design. How quickly the ramp rates open and close the valves makes a HUGE difference in performance. It's what allows a MUCH milder cam from CompCams make the same peak power as an E cam, with much better bottom end and drivability. If I were you, I'd save a little more money, even if it takes longer, and get a custom, or go with an XE264 - XE270 if you want something a little stouter." So if you have the money go with comp, i did and couldnt be happier the motor pulls great.
R
Ray@VSK
355
#11
  • Apr 19, 2005
  • #11
Hey the Steeda cam is nice & cheaper than the alphabets.
skip nay
110
Chambersburg Pa
Apr 19, 2005
#12
  • Apr 19, 2005
  • #12
F cam will work with no piston to valve worries!(that was even with performer RPM heads with 1.90,1.60 valves and 1.6 roller rockers) I would change springs if using stock heads. If you go to something other than that E or B will works also. Make sure no more than 226@.50 and a total lift of no more than .520 at most. Hope this helps good luck.
88 5.0 hi perf
34
#13
  • Apr 19, 2005
  • #13
will the trick flow stage 1 cam pass smog?
pisgahhiker
148
Western North Carolina
Apr 19, 2005
#14
  • Apr 19, 2005
  • #14
I have F cam using crane cams rockers with crane cam springs.
I ran it with stock springs for a week or two before it busted a spring. Thank god it didn't drop a valve.
If u go with a F change those springs 4sure
Does anyone else have a combo close to this
  • 90Stanger302
  • Dec 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 25, 2025
Qtrhrse23
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
4K
Classic Mustang Specific Tech Today at 6:48 AM
GOvert
G
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
