cam choice
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Jun 15, 2009
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 15, 2009
  • Jun 15, 2009
Would you guys go with jay allen or ed curtis or lunatti? I called lunatti and they will custom grind one for me for about $350,and still waiting for ed and jay to contact me with a price. peace
john
white 89 GT
281
Tacoma
Jun 15, 2009
  • Jun 15, 2009
Here`s what I would do if your car was mine.
A set of pistons for at least 10.5 to 1 then an afm cam. Why afm, because it will run nearly as good as any of the customs, and I would put the turbo out of my head. It cost too much once you add up all the changes you will have to make to the car and suspension, a set of pistons and a cam and some gaskets and you should be mid to low 11`s around $1000
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 15, 2009
  • Jun 15, 2009
whats all involved in swapping pistons,will i get everything needed to install them?or is there something i would need to get also?you say the syspension if i go to turbo? why do you say that and what all do you mean? The only thing i think i would really need to change for the "syspension" is the rear gears. I have QA1 12 way alumn schocks air bag upper and lower rear arms moser axles driveline loop rearend gurdle rearend cover welded TQ boxes and soon to be a wolf racecraft rear sway bar. the front is tubular k memeber adjustable coil overs tubular arms.peace
john
white 89 GT
281
Tacoma
Jun 16, 2009
  • Jun 16, 2009
It looks like the car is setup to handle the extra power, many forget about that extra power on things like axles.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
9
Does anyone else have a combo close to this
  • 90Stanger302
  • Dec 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 25, 2025
Qtrhrse23
C
Drivetrain Need assistance
  • ChrisPBacon323
  • Dec 7, 2024
Fox 5.0 Mustang Tech Dec 30, 2024
C
Engine Can change - valve springs also?
  • Cg’s 347
  • Feb 17, 2024
2K
Fox 5.0 Mustang Tech Feb 22, 2024
2000xp8
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
