I am little confused on checking cam end play. Did a search and come up with different ways of checking it. The way I did it, is put the thrust plate and cam gear on. Then used a dail caliper on the face of the came gear and moved cam back and forth. Got a movement of .040. The roller thrust plate I have stated .004-.014 is recommended.
So I did the search, to see what I need to take up the extra space. But I found people saying different ways of checking it. I did it like how comp cam said do it, with a dail caliper and move cam back & forth in block. But the I read where people say "End Play" is the clearance between the back of the cam gear and the front of the cam. And can use a feeler gauge to check... And can be done with cam out of motor..
Any input on this will be 'GREATLY APPRECIATED!!!"
