I disagree. #2 would traditionally be the better choice,here's why: Although the LSA is worse on #2 the reduction in duration more than makes up for it. The tighter LSA will allow more pressure to bleed off but #2 has 17 and 12 degrees less duration @.050,(who knows how much less the total duration difference actually is!!),so you're going to have less overlap than #1. Less overlap,more power,especially in the lower rpm range. Now if you're building a track only,high rpm race motor then yes,go big but you'll have a much more driveable,less finicky engine with #2 and the power difference will be small. 220/230 is still pretty healthy for a small cube engine and is 15-20 more degrees than factory so you're still moving up from factory cam power levels.
