Cam,Head, Piston Clearance?????
  • Thread starter Thread starter 408WBlackCoupe
  • Start date Start date Mar 28, 2011
408WBlackCoupe
29
  • Mar 28, 2011
OK I'm wanting to put some AFR 185 2.02/160 heads with a TFS stage 1 cam 499/510 Sock bottom end never been decked. Was Wondering if anyone knew if it would work with out having to notch the piston, or if it would clear? I think it will but just want a second opinion.
Thanks Nathan
Rick 91GT
Mustang Master
95
99
PA
Mar 29, 2011
  • Mar 29, 2011
Nate is will be close, you'll have to clay it.. Usually you run into radial clearance issues on the outside edges of the eyebrows with the large valve, the center of the notch nearly always clears. Ive seen stock piston to deck heights vary over .018"
408WBlackCoupe
29
  • Mar 29, 2011
Thanks. I didn't want have to clay it but will just to be safe.
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Engine Heads and how to buy
  • Dontknowchit
  • Aug 16, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
