cam help please
  • Thread starter Thread starter tvmango
  • Start date Start date Dec 9, 2003
tvmango
667
bradenton florida
Dec 9, 2003
  • Dec 9, 2003
these are the 3 cams I'm trying to decide on
1 is the trick flow for $139.00
Specifications:
* Advertised duration: 275 intake/279 exhaust
* Duration at .050 in. lift: 221 intake/225 exhaust
* Gross valve lift: .499 in. intake/.510 in. exhaust
* Lobe separation: 112 degrees
* RPM range: 2,000 to 5,500
2 is the e303 for $165.00 Advertised duration: 282 intake/282 exhaust
Duration at .050 in. cam lift: 220 intake/220 exhaust
Gross valve lift: .498 in. intake/.498 exhaust
Lobe separation: 110 degrees
Peak horsepower rpm: 5,500
Peak torque rpm: 2,500
Good idle
3 is the f303 for $189.00
Advertised duration: 288 intake/288 exhaust Duration @ .050 in. cam lift: 226 intake/226 exhaust
Gross valve lift: .512 intake/.512 exhaust
Lobe separation: 109 degrees intake/119 degrees exhaust
Peak horsepower rpm: 6,000
Peak torque rpm: 2,800
Fair idle
My car is not a race car, will be brought to the track once in a while, but is just a summer toy. So driveability is a factor.... thank you
I am keeping my block stock this year, but adding all the stuff below....
tvmango
667
bradenton florida
Dec 9, 2003
  • Dec 9, 2003
please guys....
TIMMY2734
1,330
Queens, NY
Dec 9, 2003
  • Dec 9, 2003
id go custom. For another couple hundred, youll have one that meets just your needs. You should also try checking out some of the Anderson cams.
tvmango
667
bradenton florida
Dec 9, 2003
  • Dec 9, 2003
please!!!!!! I need to order a cam,,,,,
tvmango
667
bradenton florida
Dec 9, 2003
  • Dec 9, 2003
yeh but 300$$ !!! I will get a custom cam next year when i do up my block. That way I can go crazy, I just want it to rip next summer.
R
redterror302
895
Mertztown, PA or State College, PA
Dec 9, 2003
  • Dec 9, 2003
Is that put in your GT with the charger on it? If so, I would go with either the f cam or the tfs 1 cam. The idle you probably are looking for will be there, and the boost will get you into the upper roms where the cam will rip! Ask JadeFalcon. He has an f cam with a charger, and he is shifting the thing at 7k rpm!!!!!
Just my choice though if you don't want a custom cam right now.
Chris
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
Engine Valve and or rocker noise .....new to this but dont mind getting my hands dirty.
  • mustang matt 1993
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 1, 2024
rednotch
I
289 cam break in help
  • iaff284
  • Aug 19, 2022
1965 - 1973 Classic Mustangs -General/Talk- Aug 19, 2022
iaff284
I
F
carb vs cam help needed
  • forango
  • May 2, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2025
forango
F
