Cam help
  • Thread starter Thread starter Ricky D
  • Start date Start date Aug 2, 2004
Ricky D
124
canada,quebec
Aug 2, 2004
  • Aug 2, 2004
Hi everyone!
Here`s my problem, I need help finding a good cam for my ride....
The car is 2800 pounds ,With a SVO crate engine with GT 40 aluminum heads.
It has now a b-303 for efi
I run the car with a carb 600 cfm vac sec performer rpm dual plane.
I plan to instal the sniper kit 150 hp nitrous later this year
The car runs now 13.0@114 mph
I have a c-4 but I`m going to switch to a T-5
The rearend in 8.8 posi 3.73 gears with SVO axle grid, 26 inch tire Hoosier DOT
I want the car to a a semi rough idle with enough vaccum for my brakes...
The compression is 9to1 I will put Motorsport roller rockers 1.6
I was thinking about the F cam or the e cam...I want to go hotter than the B
but not too much lift that I end up with piston clearance..
I read that when you use a carburator the lobe separation of the cam needs to be different than an EFI cam
I`m sure this description rings a bell somewhere So if you have a good sugestion that was track proven Than please let me know
Thanks a lot guys!
DirtyD916
804
Norcal 916
Aug 2, 2004
  • Aug 2, 2004
the advice i can give you is contact ed curtis and flowtech induction as he can make you a custom grind taht incorporates all of the things you want in your car.
hllon4whls
BANNED
2,567
Covington
Aug 2, 2004
  • Aug 2, 2004
Or lunati, comp or a good reputable cam builder.
The seperation on and EFI car has a limit of what works well and what doesnt. A carb will run with any cam.
Comp has a bunch of EFI ready cams for any performance level.
M
Mhypertext
30
Joplin MO
Aug 2, 2004
  • Aug 2, 2004
the F and E cam ARE NOT BETTER THAN THE B
I have tried them all
get the middle sized trick flow cam
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
Engine Cam idle and timing questions - big cam, little knowledge
  • Justin87
  • Jul 6, 2021
12K
Fox 5.0 Mustang Tech Jul 31, 2021
Middleagecrisis
M
T
Engine GT40 Heads + Cam Help
  • Tancalhan
  • Jun 4, 2021
7K
Fox 5.0 Mustang Tech Jun 7, 2021
Dan02gt
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
Help me figure out this 5.0 HO I pulled out of the P.N.P.
  • Cool Beans
  • Feb 10, 2019
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2019
Cool Beans
