cam install
first off biggest badest cam will not be that streetable. second the b-cam isn't usually in the same sentance as biggest and badest. look into FAQ at the top of the page and look at some member combos. i would suggest either the steeda #19 or an Anderson cam.
FITS????
The steeda cam dosent have any specs listed on the page. also im worried about piston to valve clearance issues. What would be the best came for the situation i am in. The AFR heads have 1.90 intake and the pistons are stock GT. i dont want to buy a 200 dollar cam put my playdough in the cylinder and then find out that the cam is too big. also what rockers should i run. i have a cobra cam now with 1.7:1 rollers. can i stay with the 1.7:1's or do i need to buy 1.6's|???????
Custom cam.
I've seen a lot of success with Ed Curtis at FlowTech Induction, Brian at HiTech Motorsports, and Jay Allen at Camshaft Innovations. They will be able to set you up with exactly what you need, given what you currently have.
My .02.
Adam
