Cam Keeper Question
bluestang65
22
I just got a 4.6L Cheap from a MarkVII. By cheap I mean $100 and it has compression. Upon teardown, everything looks great right down to the perfect cylinder walls. Here's the question: There seems to be nothing tieing the exhaust cam to its gear in the timing system. Sure, there is a spot for a key on both the cam and the gear, but neither side had anything in the keyway and the cam spins independently of its gear. Call me crazy, but I can't figure out what is supposed to operate the exhaust valves if that cam gear isn't connected to the cam, Right? What am I missing in this engine to make the cam turn with its gear? Maybe I have spent too much time with my small blocks. I just thought I would get with the times and start toying with the Modular motors. Let me know. Thanks.
Sounds like the kewway the ties the cam and gear together is missing or broken. Probably why the engine was sold for so cheap,wouldn't run that way. A new keyway should be relativle easy to come by but inspect everything closely on that side for a reason why it sheared off in the first place.
