Last Saturday I began my engine assembly. Stock 289 rebuild. I'm using a Comp Cams flat tappet (bought it in 1995). The lube packet that came with it was a red, viscus liquid, instead of a grease consistancy that I remember from many years ago. I'm nervous that this lube has already fallen off the cam lobes and I'll be starting unprotected. Has anyone else used this lube? I think it's Comp Cams P/N 103 and as stated above, it was supplied with the cam. I plan to finish the assembly and fire this thing up over the next 3-4 days.
I put the valve train in this evening and started to adj the valves. I am using the book "How to Rebuild Your Small Block Ford" as my reference and using the "3-crank position method" to adjust the valves. I think step 1 is to put the crank @ TDC and adj #1 intake & exhaust, and a few selected others. The move the crank, do a few more, then one more position for the rest. On position 1, I am to adj one of the #7 valves (I forgot which one). I ran the nut all the way down and the slack never came out of the rocker. Should I have started one more revolution @ TDC? Is there another reference or different method anyone uses to adjust these valves? I don't want to screw anything up.
Any advice on these two concerns will be greatly appreciated.
Rob
Rob
