Cam ok for my car?
Black93 - I think you'll be disappointed with the way it runs. It might have the cam sound at idle, but that cam and most off the shelf units are designed to be used with better flowing heads, intakes and exhaust systems. If you put them in a near stock set up, they really kill the bottom end of the engine - and usually for little if any gain on the top end. And, as pointed out above, they also overwhelm the stock valve springs. Get the rest of your mods ready to go before you put the cam in. RE: your other post - if you think yours lugs in 5th bad now - go ahead and put the Stage1 cam in a basically stock motor. Then you'll understand the meaning of the word "lug". :)
