  • SN95 4.6L Mustang Tech
CAM QUESTION
  • Thread starter Thread starter happydood2
  • Start date Start date Jul 2, 2004
happydood2
81
MA
Jul 2, 2004
  • Jul 2, 2004
I just bought some pi heads from a 99 mustang gt for my 98 mustang gt and i want to get some good cams in place of the pi ones that came with them. I removed the cams and i want to sell them on ebay. I was wondering if the gear on the cams which the timing chain goes on comes with the new aftermarket ones im getting. It doesnt look like it can be removed from the cams i have now but i didnt really try to hard because i dont want to break something.
R
Ryan L
783
St. Augustine, FL
Jul 2, 2004
  • Jul 2, 2004
In 99-00s, the cams are pressed into the gears. I don't know how you would remove them. 01+'s are bolted in, so it makes a cam swap a piece of cake.
J
joestang98
187
Vienna,WV
Jul 2, 2004
  • Jul 2, 2004
sorry to but in on your post but do the cams in the NPI heads are the cam gears fixed to the cams?? or are they removable also? Just wanted to know because I want to go with a set of comp cams in my NPI heads??? Thanks!
NicksBullitt
172
Holly Ridge, NC
Jul 2, 2004
  • Jul 2, 2004
cam gears
I don't know about all GTs but I was under the impression that all GTs had the cam gears pressed on(may be wrong). My bullitt has them bolted on and the gears can be reused. If the gears look pressed on they will have to be replaced. If I remember correctly the gears are less than $100, somewhere about 50-60. Hope this helps.
mpcv2000
2,371
Montreal , Quebec !
Jul 2, 2004
  • Jul 2, 2004
96-98 and 01 up the gears are bolted on , only 99-00 ( Windsor ) are pressed on. You can buy a gear kit for $69.95 here ! .
You can get some nice 2750 Stage II here but I'll have to check cause when you use PI heads on a Non PI engine you will raise the compression ( piston dish is different ) so clearence can be a issue if you raise the lift but like I said I'll have to check on this.
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
Foxbody Intro
  • 5.0Sucio
  • May 26, 2026
  • The Welcome Wagon
The Welcome Wagon May 26, 2026
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
I
I'm gonna have so many questions (but I know how to search)
  • ironhorsewayne
  • Jun 7, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 8, 2026
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
