  • 1994 - 1995 Specific Tech
cam question
  • Thread starter Thread starter fiveoho
  • Start date Start date Feb 18, 2007
fiveoho
1,958
TN
Feb 18, 2007
  • Feb 18, 2007
218/226 @ .50
.500/.510
replacing 1.6's with 1.7's on the specs above, what would that change the lift and duration to? is there a formula to accuratly figure that?
thanks guys
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 19, 2007
  • Feb 19, 2007
basically devide your lift by 1.6 then multiply by 1.7. it will change the lift but it shouldn't effect the duration much if at all.
fiveoho
1,958
TN
Feb 19, 2007
  • Feb 19, 2007
.531/.542 ?
duration the same
*the cam has a ls of 112. how would this do in a smaller NA stroker setup?
S351Saleen77
423
Washington
Feb 19, 2007
  • Feb 19, 2007
Duration will increase 1 to 2 degrees also when changing ratios. Hope this helps
To determine the change in lift when changing rocker arm ratios, divide the lift of the cam by the original rocker ratio (which gives you the lobe lift), then multiply this number by the new rocker ratio. For example, the stock Mustang 5.0L HO cam has .444” at the valve. Divide this number by the stock rocker ratio of 1.6 to get the lobe lift, .2775” and multiply by the new rocker ratio 1.72, to get the new lift of .477”.
fiveoho
1,958
TN
Feb 19, 2007
  • Feb 19, 2007
that does help. thanks man
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Wednesday at 1:55 PM
skidad
