cam Questions
  • Thread starter Thread starter mr_bird
  • Start date Start date Sep 12, 2005
First Prev 2 of 2
vristang
4,933
101
124
Seattle
Sep 14, 2005
#21
  • Sep 14, 2005
  • #21
mr_bird said:
so after a bit of bargaining with my parents they let me use the money i have in the bank for my car, so i've decided to just go with the trick flow twisted wedge top end kit, it makes around 350 hp, and i think that will be plenty. I still have a few questions though, i was wonderin if i should install a bigger TB, MAFS, injectors, and fuel rails to accomodate the new equipment. Plus it says that it makes this power with a .30 over 306, do you guys recommend rebuilding the short block as a 306, the one i have now has bit less then 70k miles on it and the engine right now seems to pull strong, so im not too shure what to do, what do you guys think?
4 ci won't make much difference to the power. Stock 19lb inj are a bit small for 350hp, by my calculations. It would be nice to upgrade the maf and tb, if you still have the cash after the kit.
I would also recommend a fuel pump as follows.
You can't really get too much fuel pump unless you are talking about the $$$ expense, or possible noise. The regulator takes care of extra pressure and the return line takes car of extra flow.
Here are some recommendations that I worked out according to formulas I found in Four Stroke Performance Tuning by A. Graham Bell. Running at 80% of plump capacity helps ensure a long life from the pump.
_____________________80% of Max______80% of Max
Ford EFI Options_______N/A Limit________Boost Limit
110 lph________________240 hp__________200 hp
155 lph________________340 hp__________280 hp
190 lph________________420 hp__________340 hp
255 lph________________560 hp__________460 hp
I recommend considering future plans when deciding on a fuel pump.
First Prev 2 of 2
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
