I am about to dump a lot of technical information on you. I suggest that you not disregard it because it doesn't match you plan. I recommend that you print it out and read it through carefully. Use Google to find answers to things that you don't understand. When you understand all the tech data, it will make perfect sense. You will have a good idea of what you need to do to make the truck run really good and not some hack job that can't keep up with a 4 cylinder Honda.
If the block is drilled for the spider, it will fit. You will need to replace the valve springs since they were not designed to work with the fast opening rate of any roller cam and high RPM operation.
Note the shape of the roller cam – the ramp is much steeper than the ramp on a flat tappet cam. That sudden acceleration from closed to full open is hard on springs and they need to be designed to work correctly with roller cams.
The E cam may change the firing order which will give the computer fits.
Check the firing order before you do anything with the E cam.
This doesn’t prove that the block is a HO block. Some trucks evidently use a HO firing order with a low lift cam (this will result in less than the desired HP output). However, it will definitely prove that a block can’t be HO because the firing order is wrong.
Remove the #1 & #3 spark plugs. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Slowly turn the engine until the TDC mark and the timing pointer line up. Mark TDC on the balancer with chalk or paint. Put your finger in #3 spark plug hole and crank the engine 90 degrees. You should feel pressure trying to blow past your finger. If you do not feel pressure, repeat the process again. If you feel pressure, it is a HO engine.
No pressure the second time, remove spark plug #5. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Put your finger in #5 spark plug hole and crank the engine 90 degrees. If you feel pressure now, the engine is not a HO model, no matter what it says on the engine.
Using a small carpenter or machinist square to mark the harmonic balancer off into 90 degree sections may be helpful here.
A 15/16 deep socket & breaker bar or ratchet may be used to turn the engine.
The HO firing order is 1-3-7-2-6-5-4-8. The E cam uses this firing order.
Non HO firing order is 1-5-4-2-6-3-7-8
The cam determines the firing order for the engine since it determines when the valves open and close.
Using the E cam requires you to use a computer that matches the firing order. If you don't, all the injectors don't squirt when the intake valve is open and the O2 sensors can't properly adjust the air/fuel ratio. It sees the O2 sensor output and tries to adjust the air/fuel ratio. Normally when the computer and cam have the same firing order, that's good.
BUT when the firing order and computer don't match, it sees the O2 sensor output and tries to adjust the air/fuel ratio.
The problem is that it adjusts the wrong cylinder bank because the computer doesn't know which cylinder bank it is adjusting the fuel trim for. That is due to the difference between the 1-3-7-2-6-5-4-8 firing order that the E cam uses and the 1-5-4-2-6-3-7-8 firing order found on some trucks and most passenger cars. With a mismatched computer and cam, only cylinders 1, 2, 6 and 8 have the fuel injectors squirting when the intake valve is open. The result is that the engine runs rough at low speed and is sluggish to accelerate.
The fix is to either swap the computer and engine EFI harness or use a cam that matches the firing order that the truck has. Since the truck is probably speed density, a MAF conversion is in order.
Speed Density uses Manifold vacuum (MAP), Throttle position (TPS) and RPM, & Air Temperature (ACT) to guess how much air the engine is pulling in. Then it uses all of them plus the O2 and ECT sensors to calculate the air/fuel mixture. It is dependent on steady manifold vacuum and minimal changes in airflow from the stock engine configuration to maintain the proper air/fuel ratio. Change the airflow or vacuum too much and the computer can't compensate for the changes, and does not run well. Forget about putting a hot cam, a supercharger, turbocharger or monster stroker crank in a Speed Density engine, because the stock computer tune won’t handle it. Every time you seriously change the airflow through the engine, you need a new custom burned chip to make the engine run at peak performance.
Mass Air uses a Mass Air Flow meter (MAF) to actually measure how much air is being pulled into the engine. The computer uses this information and inputs from the O2, TPS, ACT, ECT, RPM and Barometric Pressure (Baro) sensors to calculate the proper air/fuel ratio. It is very tolerant of changes in airflow and vacuum and tolerates wild cams, high flowing heads, and changes in displacement with minimal difficulties. Larger injectors can be used with an aftermarket calibrated MAF or a custom dyno tune. This makes it possible to use the stock computer with engine displacements from 302-408 cu in, and make many modifications without a custom dyno tune chip. Put a new intake manifold on your 331 stroker and the computer figures out how much more fuel to deliver without having to have a new chip burned to accommodate the extra airflow.
