  • SN95 4.6L Mustang Tech
Cam selection
  • Thread starter Thread starter stang_man_1
  • Start date Start date Feb 18, 2006
stang_man_1
24
  • Feb 18, 2006
i was thinking of getting a new set of cams but i don't know where to find them. Can somone explain what the stage 1 and stage 2 cam sets are and where to get them. how much do they cost. Any info would be greatly appreciated.
Built98GT
211
OKC
Feb 18, 2006
  • Feb 18, 2006
If you do cams i suggest you do the headswap first.
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Feb 18, 2006
  • Feb 18, 2006
Agreed. Much better off with the headswap & PI cams that come with it than getting aftermarket cams on a non-PI motor.
stang_man_1
24
  • Feb 18, 2006
thanks
69Rcode_Mach1
1,473
Salt Lake City, Utah
Feb 18, 2006
  • Feb 18, 2006
I agree you will not be able to take advantage of those cams without the proper flow from the heads. Do the heads and the Stage 2 cams and you will feel a nice kick in the pants, and a mean idle.
'03GTinFLA
486
St. Petersburg, FL
Feb 18, 2006
  • Feb 18, 2006
I can only speak for the VT cams as far as stage 1 and 2 are concerned, but I have heard stage 1 gains from 22-33 hp. Stage 2 is a little more, but not really worth it on a small to mildly modded car. Stage 2 does best with full intake and exhaust with heads.
Two other differences to be aware of are lope and springs. Stage 2's have a rougher idle,, and you should get a tune with stage 2's. I've heard of people running 1's without tune and doing fine.
Stage 1's don't require new springs, stage 2's do.
So I would suggest PI swap and then stage 1's. Unless you are planning ahead and have lot's of other mods to do.
Hope this helps, just my .02 from searching for my choice of cams.
TweekedGT
1,274
Alberta
Feb 18, 2006
  • Feb 18, 2006
I agree with all of the above. I have VT stage 2 N/A cams on my heads right now and have been very happy with them. They are coming off this week and Crower stage 2 blower cams are going on. I would have gone VT blower cams but they don't have any in stock. Stage 1 or 2 is just the determination of how much duration and lift the cam has. The higher of both they will call it a stage 2 or 3. Anything with a stage 2 or 3 is usually a little more of a rough idle and requires extra components be installed. With a stage 2 or 3 cam you will require 3.73 gears or higher as well as upgraded valve springs.
stang_man_1
24
  • Feb 18, 2006
will the new 3-valve heads fit my engine
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Feb 18, 2006
  • Feb 18, 2006
Whoa...I have to disagree. I have Comp 262's (comparable to VT stage 1) in my NPI car and I got a really nice gain for a hell of alot cheaper than the pi headswap. Before the cams (with a PI intake on NPI heads) I hit 208HP w/269TQ (Dynojet). After the cams and a tune I was at 230HP with 273TQ. The dyno tune was on a Mustang dyno so the gains compared to the Dynojet are probably a little less. If I had to guess I would make 235-40 on a Dynojet.
stang_man_1
24
#10
  • Feb 18, 2006
  • #10
anybody please!!!!!!
TweekedGT
1,274
Alberta
Feb 18, 2006
#11
  • Feb 18, 2006
  • #11
I do not believe so. If they do you would have to do way more than just the heads and intake like a 99-04 headswap. Totally different intake set up.
TweekedGT
1,274
Alberta
Feb 18, 2006
#12
  • Feb 18, 2006
  • #12
Not knocking you by any means but mine made 280rwhp on a Mustang dyno with VT Stage 2's and the headswap. That's over 300 on a dynojet. Headswap is worth it.
T
TGJ
1,049
#13
  • Feb 18, 2006
  • #13
I would say it all depends on what you intend to do with the car. The PI head swap is worth about 10 - 15 RWHP more than a PI Cam and PI Intake swap on a NPI car due to the compression bump. There is a misconception that the PI head is better than the NPI head when in reality the PI head has a better intake and cam. Having both on the same compression level, the NPI head makes just as much power as the PI head with the same cam and intake. Been proven numerous times at MD and TCCOA.
That all being said, if you want to run the stock shortblock and intend to stay N/A, the PI headswap with aftermarket cams is a good bang for the buck. No matter what you do, I would do an aftermarket cam and PI intake swap on that NPI car. The cam and intake swap will be cheaper.
01Steeda
732
Baton Rouge, LA
Feb 19, 2006
#14
  • Feb 19, 2006
  • #14
I dont know this for sure.. but I have been told porting the NPI heads can yield more than the PI swap. makes sense to me.. just dont have anything to back it up.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
D
2006 Roush Stage 2 Mustang Chin Spoiler/Lower Grill Inserts Needed
  • DG_Damn_Good
  • Oct 13, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 14, 2026
DG_Damn_Good
D
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
