im thinking about installing a bigger cam,i have never selected a cam and i'm lost on this subject....i'm looking for 300 horse power n/a with my combo listed in my signature......thanks..below is what im looking at...good bad or ugly?
Part Number: 444222 Grind Number: POWERMAX 2030 (FORMERLY COM
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1985 Up FORD-MERCURY 8 H.O.
Engine Size Configuration
302 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake cam 333 @Valve 533 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 340 @Valve 544
Rocker Arm Ratio 1.60
Cam Timing: --- @---
Lift: Opens Closes ADV Duration
Intake --- --- 270 °
Exhaust --- --- 278 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99841
Loads Closed 113 LBS @ 1.950 or 1 61/64
Open 338 LBS @ 1.430
Recommended RPM range with matching components
Minimum RPM 1400
Maximum RPM 5400
Valve Float 6000
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 1 BTDC 35 ABDC 107 216 °
Exhaust 47 BBDC (7) BTDC 117 220 °
Remarks:
FIRING ORDER: 1-3-7-2-6-5-4-8
302 C.I. V
Part Number 99841
Minimum RPM 1400
Maximum RPM 5400
Valve Float 6000
Remarks:
