Been a long time since I've posted on here. My account was hacked (Giddyup306). If a mod sees this, I'd like to know if I can get my Founding Member stats back.
Anyways, I have a set of these. I'm being a guinea pig for these. The machine shop that I go through said they have problems with the Pro Stock heads ripping out rocker studs. They are only rated at .500" lift. I have one of their cams, but no cam card!? You're kidding. I've bought a few SP products, and their customer support is non-existent.
I'd like to see what numbers or times you have for anyone that used them. I'm replacing the 2.02" valves with 2.08 or 2.05 intakes. The exhaust will be 1.65.
This is going on a 435 Windsor. With 210 CC runners it will run out of steam around 8K. This is a n2o engine. I learned long ago to make as much engine power as possible and go with a nitrous grind.
I've been out of the Mustang scene for a while. This is to replace my 9,500 RPM alcohol engine that was stolen.
So... am I the only one dumb enough to go with something crazy? After EXing them I'll do a 6 angle valve job and some hand porting/polishing/blending.
