Cam Selection
  • Thread starter Thread starter Dan93SVT
  • Start date Start date May 18, 2014
1 of 2 Next Last
D
Dan93SVT
28
  • May 18, 2014
I just ordered a Boss 302 block and i think my cam selection should be next, i want a street motor that will not see higher than 6,200 rpms and i have been looking at some off the shelf cams like the Comp xe274 and xe270
Im looking for opinions from people who have run these cams before or opinions on off the shelf vs a custom cam.
I will be buying a Scat forged 331 rotating assembly and AFR 185 heads, i might possibly supercharge in the future and i know that cam selection is important, also what compression ratio should i be aiming for with this build. Thanks
rbohm
6,698
550
204
tucson,az
May 18, 2014
  • May 18, 2014
the XE comp cams are good ones. we put one in my friends camaro when we built the engine on it. it idles well, and makes power through the rpm range. it does need a bit higher idle though, so be aware of that.
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 18, 2014
  • May 18, 2014
the tech guys at comp are really helpful too
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
May 18, 2014
  • May 18, 2014
What are your goals? Considering you went with a Bods block I'm assuming you actually wanna make some power
D
Dan93SVT
28
  • May 19, 2014
My goals are a to turn my 93 Cobra into a fun weekend driver that has power, reliability and is fun to drive on the street, what i don't want is a race gas high strung small block that makes its power from 3500 to 7500 and is a pain to drive in traffic. The reason for me going aftermarket block, forged internals and AFR heads is reliability and i may supercharge in the future i just don't know what cam I'm going to go with
bentley429isBAC
922
188
84
CT
May 19, 2014
  • May 19, 2014
Not a off the shelf one.
Reactions: tannerc91gt
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 19, 2014
  • May 19, 2014
I'm running a H/C/I 331 stroker set up with the XE274HR camshaft. Runs well, pulls good vacuum down low, has a nice choppy idle and makes power all the way to the rev limiter. No complaints.
I initially thought it was a little bit soft in the bottom end, but then quickly realized it's because it made so much more power in the mid and top RPM ranges than the stock cam did.
Nothing at all wrong with running an off-the-shelf cam.
On a sidenote, there's really no need to forge the block, or the bottom end with the power levels those parts would produce on a street engine running less than 6,500RPM. Unless you plan on regularly exceeding 500+ horsepower, stick with the stock block, and lighter rotating assembly. Save the money for the rest of your set up.
bentley429isBAC
922
188
84
CT
May 19, 2014
  • May 19, 2014
While Na that camshaft will be ok, soon as there is a blower on it there are better options.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
May 19, 2014
  • May 19, 2014
I would try and shoot for 9:1 compression if you want to boost it.
Kurt
D
Dan93SVT
28
#10
  • May 19, 2014
  • #10
I've looked at youtube for cars running the xe274 to get an idea of the idle and from what I've seen its got a nasty idle and the stangs on there sound like they are about to stall at idle
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 19, 2014
#11
  • May 19, 2014
  • #11
True, but how many people do we know that say "might possibly supercharge in the future", or something of the like and it never gets done.
Building a forged short block and bumping up to a blower are two major (cost and effort) projects. In my experience, if they both aren't carried out the same time, one usually just never gets done at all?
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
May 19, 2014
#12
  • May 19, 2014
  • #12
Isn't that the truth. It's always, "I built this car for a blower," and then for the next 10 years you are driving around with a 300hp stroker engine.
Kurt
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 19, 2014
#13
  • May 19, 2014
  • #13
That's the sound of muscle my friend. If the sound of a rough idle bothers you that much, why consider it as one of your selections?
FWIW my car idled just fine right around 750-800 RPM.
D
Dan93SVT
28
#14
  • May 19, 2014
  • #14
Its not the sound that bothers me its how is it gonna drive around town, I'm not building a strip car if i was i would get a notch, gut it and drop a 408w in it and be done with it, and yes most people say "someday" to car upgrade mods but its a good thing I'm not most people or a pimply faced teen anymore I'm at the point in life where if i want to buy a supercharger for my car i do it, you can't take the cash with you to the grave. Im just looking for opinions on a cam that would run well with my parts list
tannerc91gt
2,967
234
Indiana
May 19, 2014
#15
  • May 19, 2014
  • #15
Sums up Stangnet pretty much
bentley429isBAC
922
188
84
CT
May 19, 2014
#16
  • May 19, 2014
  • #16
It will be fine. Its a pretty mild cam. I am guessing you'd do a smaller supercharger correct? Si maybe a D1sc or so?
D
Dan93SVT
28
#17
  • May 19, 2014
  • #17
Yes sir i don't plan on running much boost
D
Dan93SVT
28
#18
  • May 19, 2014
  • #18
I would like to enjoy my engine until i get bored with it and want to throw a supercharger on it, my buddy is running a turbo on his and says thats the way to go over supercharging
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 19, 2014
#19
  • May 19, 2014
  • #19
For some yes, for others no. Both have their advantages and disadvantages. I'd stick with the blower for a street car personally. Yes, you'll give up a little power, but most blower set ups are less complex, with better drivability and a more stable and repeatable power band. And pretty much all are capable of exceeding 500hp.
And I wasn't inferring that you were a pimply faced teenager with my previous comment. That just seems to be the way it is. Whether it's money, or loss of interest, A change in priorities, or something else. People are always changing their minds.
D
Dan93SVT
28
#20
  • May 19, 2014
  • #20
yeah i hear ya i lost interest in mustangs for 6 years while i went on my old ford truck obsession, 66 F1oo swb, 79 F100 swb 460, 77 F150 4x4 swb, 70 F100 swb, 79 F100 lwb but i sold all those and have my 93 cobra back living in my garage. If i supercharge it will be down the road and its not a complete factor in the engine i want for my car
1 of 2 Next Last
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
R
Progress Thread 351w stroker rotating assembly and build
  • Ric4eyedFox
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 24, 2025
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
