Cam suggestions
  • Thread starter Thread starter kck6894
  • Start date Start date Sep 3, 2009
kck6894
Advanced Member
Mar 18, 2004
Paradise
Sep 3, 2009
  • Sep 3, 2009
I have a 94 Cobra that has just some minor mods. 70mm Throttle body, BBK shorty headers, OR x-pipe, and and AEM computer. I have a pair of old TFS heads that I was considering putting on it.
Anybody got any ideas on a Cam for it?
Should those stock 24lb/hr injectors be ok or do you think I'll need more injector?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 3, 2009
  • Sep 3, 2009
What kind of TFS heads are they, and how much do you want to spend on the cam?
Kurt
kck6894
Advanced Member
Mar 18, 2004
Paradise
Sep 3, 2009
  • Sep 3, 2009
They are a set of the original Twisted Wedge heads. I think they flow like 250 at .550 lift on the intake side.
I'm not too worried about the price of the cam since it's the only thing aside from gaskets I'm gonna be buying.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 3, 2009
  • Sep 3, 2009
I guess if you don't care how much money you are going to spend I would call one of the custom cam guys and get a custom cam ground.
Kurt
kck6894
Advanced Member
Mar 18, 2004
Paradise
Sep 3, 2009
  • Sep 3, 2009
Kurt
I knew that was the response I was gonna get. I was really more interested in just a simple off the shelf cam. If I was gonna do a custom grind I'd do one for the 347 in my fox. I might look into it anyways though. Thanks
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 3, 2009
  • Sep 3, 2009
I was trying to give you the right answer I guess. I recommend a Trick Flow 2 cam if you get an off the box cam.
Kurt
kck6894
Advanced Member
Mar 18, 2004
Paradise
Sep 3, 2009
  • Sep 3, 2009
Kurt
Oh yeah it's probably the best cam I can get but it's just my DD and seems like a kinda of a waste of a custom cam. Obviously those heads are capable of supporting way more cam and HP than the rest of the combo is so to me it seems like a waste. A good off the shelf cam seems like a better fit. I appreciate the help and the advice!
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 3, 2009
  • Sep 3, 2009
Understandable. I have never had a custom camshaft myself.
Kurt
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Sep 4, 2009
  • Sep 4, 2009
Well if its your daily driver, you probably want a good idle and good power from idle - 3,000. A custom cam to me, is great for daily drivers because you dont have to sacrifice as much to get what you want. Obviously you want to make the best out of your combo and you dont want a headache everyday...sounds like a custom cam job to me. Because it seems that off the shelf cams make you choose, kinda like that new Mac vs. PC commericial. PC's make u choose your features vs. mac being good at everything lol.
Ok, back on topic though. I think the stock 24lb injectors should be fine. All i have ever had were custom cams...1 from Jay Allen and 2 from Ed Curtis. Before going with a TFS stage 2, be sure u talk to guys who run that in a 302 since it will be your daily driver. The TFS package uses the TFS stage 1. So thats obviously an option. The only other thing i'd say is to look at AFM's cams....i've seen great power made with those. But they are expensive....and at that point, you may as well get a custom cam and get exactly what you want.
Since its your daily driver, off the shelf wise i'd probably say a TFS stage 1. But post what you want to "deal with" and what u want out of it, and maybe guys can help a little bit more.
I
inphiniti
412
Providence, RI
Sep 4, 2009
#10
  • Sep 4, 2009
  • #10
i agree with Nate as far as the AFM... im running a B31 cam in my car. its supposed to be a great blower cam, but its just as good N/A.. i dont have any tuned/dynoed numbers yet but the car halls ass!
are u changing your intakes up at all?
here are the AFM cam specs i found
Blower Cams
B-1.......220/222 .490/.530 110
B-2.......218/224 .524/.544 w/1.6 rocker 112
B-21.....218/226 .542/.542 w/1.7 rocker 272/280 112 108
B-25.....218/226 .544/.544 w/1.7 rocker 272/280 112
B-3 ......218/226 .542/.542 w/ 1.6 rocker
B-31.....218/228 .544/.544 w/1.6 rocker 270/280 112 108
B-4.......224/232 .542/.563 112
B-41 ...228/236 .544/.544 w/1.6 rocker
B-451..232/240 .576/.576 w/1.6 rocker 112
B-4R....226/234 .544/.544 w/1.6 294/302 (renegade cam)
B-61.....240/248 .576/.576 w/1.6 rocker 112
Naturally Aspirated Cams
N-111....248/258 .576/.576 w/ 110 LSA
N-21......219/229 .512/.512 w/1.6 rocker 110
N-3........218/226 .542/.542 w/1.6rocker 280/288 110
N-4........222/230 .512/.512
N-41......222/232 .512/.512 w/1.6 rocker 110 106
N-51P....228/238 .499/.4976 w/ 1.6 rocker 110 (pure stock cam)
N-51HR...226/234 .520/.528 w/ 1.6 rocker 110
N-61......228/236 .544/.568 w/1.6 rocker 110
N-71......232/240 .576/.576 110
N-81......236/244 .568/.576 110
N-91......240/248 .576/.576 110 106
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Sep 4, 2009
#11
  • Sep 4, 2009
  • #11
FWIW, i've read a cobra with a ported lower goes well with twisted wedges on a 302.
kck6894
Advanced Member
Mar 18, 2004
Paradise
Sep 4, 2009
#12
  • Sep 4, 2009
  • #12
No I was just gonna leave the intake alone. It's not ideal but it will do.
I'm not worried about Idle characteristics at all or the drivablilty factor either. I ran my 347 with an AFM N111 cam on the street for years. Anything I put in this motor will be way better than that!
In all honesty I'll probably end up using another AFM cam because I've had really good luck with my N111's (I think I'm on my 3rd in this motor. OOPS. LOL) I just was wondering if anyone had anything else that might be a good option too. I'll have to check into the TFS cams though. They seem to be pretty common.
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
D
Tune erased/wont start/91 fox body
  • drew123
  • Jun 15, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 7, 2026
drew123
D
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
