ok I have a stock 98 explorer short block with an 1986 speed density stock roller cam, dog bone retainers, etc. My heads are explorer "P" heads with good valve job and milled slightly to accomdate the 52cc min rules. I'll be running a cobra upper and lower (unported) 65mm tb, 75mm mass air meter, #24 injectors, with shorties, X-pipe, and flowmaster 2.5 cat back,4:10 gears etc etc.......................here is my questions:
would It be worth it to throw on a 9 way indexable timing chain set, and run my cam at either -2 degress retard, or -4 degrees retard? I have heard great things from running a stock shortblock at -4 degress. I'm basically wanting to run somewhere in the 12.90's down to 12.50's range.......any insite will be greatly appreciated.
Thanks
Jack
Thanks
Jack
