  • 1994 - 1995 Specific Tech
CAM too much...or is there one at all!?!?
  • Thread starter Thread starter rhawk777
  • Start date Start date Jan 11, 2010
rhawk777
  • Jan 11, 2010
New owner long time enthusiust, recently purchased 95 GTand the guy said it had been rebuilt 80k ago and that it has a Ford "B" Cam...with no paperwork!!!
My first few mods i am wanting to do is MSD or other ignition,cap,rotor,wires,plugs! Wouldnt the cam affect what the ignition chioce would be?Well how do i figure out if it has a cam? Also it has really high gears and would love to make it quicker...suppossably it has 2;70's??? Any recommondations for size and manufacturer? Is it an expensive upgrade??Thanx for the input and i am sure you all will be hearing from m e alot!!lol
G
greengoblin95
92
  • Jan 11, 2010
upgrading the ignition will be fine, that cam wont affect that. is the car an auto? if it is it might seem to chop a little bit harder than a five speed. to check the gears, jack up the back of the car and see if the stock gear tag is still on the pumpkin cover, it will be attached with one of the cover bolts and it will have the ratio on that. if not, you could always spin a tire and count the revolutions
toyman
1,944
54
79
Vernon BC
Jan 11, 2010
  • Jan 11, 2010
He means drive shaft revolutions. If the gear is 2:73 you would see the drive shaft rotate 2 3/4 times for 1 wheel revolution.
Celeb
20+ Year Stangneter
Sep 8, 2002
736
Here and there
Jan 12, 2010
  • Jan 12, 2010
You'd probably know if you had a B cam. Those things are pretty choppy.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 13, 2010
  • Jan 13, 2010
If your OEM ignition is in good shape ..........
it is more than enough to deal with a NA combo to well over
300 to the wheels
Yes ... compare the amount of movement of drive shaft and tire to get your ratio
Grady
NOS JUNKY
va
Jan 17, 2010
  • Jan 17, 2010
stock ignition with what you have is fine,is the car an auto or a five speed? if an auto jmo 3.73 work well,i like 4.10's with a stick in an sn car,i had a 94 gt all stock except bbk shorty headers,off road bbk h pipe,40 series flowmasters,4.10 gear and a bbk cold air, and it went 13 teens all day long in the heat,got a couple high 12's in very good conditions(on drag radials) not sure if they all run like that but mine did,it was also a 5 speed
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Engine Cam idle and timing questions - big cam, little knowledge
  • Justin87
  • Jul 6, 2021
11K
Fox 5.0 Mustang Tech Jul 31, 2021
Middleagecrisis
M
A
Engine 1990 Fox wont rev over 3500 RPMS
  • alex.sweitzer
  • Oct 27, 2020
  • 2 3
14K
Fox 5.0 Mustang Tech Mar 21, 2021
alex.sweitzer
A
A
Engine Turbo 5.0 Mustang bad misfire at WOT
  • AwxyMoron
  • Apr 3, 2021
  • 2 3
10K
Fox 5.0 Mustang Tech May 5, 2021
a91what
T
What's it Worth? 1989 GT - What's it worth?
  • Tim83
  • May 11, 2021
  • What is it Worth?!?!?
3K
What is it Worth?!?!? Jun 3, 2021
Mustang5L5
