cam upgrade
  • Thread starter Thread starter stang_hp
  • Start date Start date Mar 11, 2007
stang_hp
62
cartersville Ga.
Mar 11, 2007
  • Mar 11, 2007
I just purchased the trick flow top end kit. It came with the stage 1 cam should I upgrade it to the stage 2 or even 3 ? I will be bolting it on a 331. Can anyone help?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Mar 11, 2007
  • Mar 11, 2007
Neither. Go custom. Should have figured everything out before buying parts. But you can always sell them.
stang_hp
62
cartersville Ga.
Mar 11, 2007
  • Mar 11, 2007
do you have any sugestions on what cam would be good with my set up?
LB0193
171
IL
Mar 11, 2007
  • Mar 11, 2007
contact anderson ford motorsport and they will point in the right direction thier cams are awsome, however there is nothing wrong with a tfs cam its a good choice, but anderson can get you a blower, nitrious, or na cam to fit your needs, also remember the more radical u go the more drivability u lose
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
2K
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
