Cam
  • Thread starter Thread starter oktw88
  • Start date Start date Dec 25, 2006
O
oktw88
11
  • Dec 25, 2006
ok i have an f303 cam and i was wondering would it work (i mean pistom to valve clearance and floating valves) in my motor with the stock heads,spring and rockers. my motor is bored 40 over and has flat tops in it. i just want to know will this cam work with stock heads,spring and rockers.until i get some different heads in the future when i get the money.
JChalfan
551
Bellevue, WA
Dec 25, 2006
  • Dec 25, 2006
Are your pistons true flat-tops, or do they have valve reliefs cut into the tops (like the stock ones)?
I don't know for sure if it will work, but this will help someone give you a good answer...
Jeff
O
oktw88
11
  • Dec 25, 2006
if i recall correctly they do have reliefs cut.... what is the max lift you can run on the stock heads and springs?
SteedaFox91
25
Rhode Island
Dec 26, 2006
  • Dec 26, 2006
if the pistons are a 'factory replacement' piston from 87-95 they will work b/c they will have the valve reliefs. You can run that cam no problem if so...You will need to upgrade your valve springs though.
O
oktw88
11
  • Dec 26, 2006
could i run a b or e cam without replacing springs. what cam can i run without replacing springs
SteedaFox91
25
Rhode Island
Dec 26, 2006
  • Dec 26, 2006
You can run the B and E cam w/o changing the vavle springs. You can most likely run any cam under about 490'/500' lift w/o changine the valve springs but why would you want to? I'd consider it cheap insurance just to get a nice set.
O
oktw88
11
  • Dec 26, 2006
i want a lopy idle for know. but in the future i do plan on getting some better heads.
thumper460
3,022
Orange Park , Fl
Dec 26, 2006
  • Dec 26, 2006
DONT DO IT!! the springs are marginal for the B cam .. the F your way out of line!! it isnt the p/v issue.. it is the spring pressures and coil bind that is... cool??
Just me.............................................
Thumper
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Clearance
  • 1993mustang50
  • Apr 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2026
2000xp8
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
