Cam
oktw88
11
ok i have an f303 cam and i was wondering would it work (i mean pistom to valve clearance and floating valves) in my motor with the stock heads,spring and rockers. my motor is bored 40 over and has flat tops in it. i just want to know will this cam work with stock heads,spring and rockers.until i get some different heads in the future when i get the money.
You can run the B and E cam w/o changing the vavle springs. You can most likely run any cam under about 490'/500' lift w/o changine the valve springs but why would you want to? I'd consider it cheap insurance just to get a nice set.
DONT DO IT!! the springs are marginal for the B cam .. the F your way out of line!! it isnt the p/v issue.. it is the spring pressures and coil bind that is... cool??
Just me.............................................
Thumper
