Camry brakes?
  • Thread starter Thread starter BlackVert
  • Start date Start date Sep 17, 2007
BlackVert
5,589
9
98
Bethesda, MD
Sep 17, 2007
  • Sep 17, 2007
Anyone ever change the front rotors and pads on a Camry? Need any special tools?
This is a 2000 Camry CE with 4 cylinders.
sleeperstang199
78
harrisburg, Pa
Sep 17, 2007
  • Sep 17, 2007
nope no special tools. the caliper bolt should be a 14mm and same for the bracket if your going to change out the rotor. if your not going to put new rotors on i recomend getting them resurfaced. my shop charges about 35 bucks to do the pair. so it should be similar to that in your area.
BlackVert
5,589
9
98
Bethesda, MD
Sep 17, 2007
  • Sep 17, 2007
thanks, i think i'll just get new rotors, they are only about $25 each. how do you get the rotors off?
F
fordtech28
312
Riverside Cali.
Sep 17, 2007
  • Sep 17, 2007
its pretty easy all you have to do is take off the caliper and the caliper bracket off and the rotor should just slide off.Or get them resurface I got my expedition's rotors resuface for 15 bucks for both .
BlackVert
5,589
9
98
Bethesda, MD
Sep 20, 2007
  • Sep 20, 2007
well, it went pretty easily. new rotors cost $21 each, the cheapest shop was $20 each to turn them, so i just bought new ones.
the only snag was that one of the lug nuts was frozen or stripped or something and wouldn't come off, so the stud snapped. of course, i didn't have an extra stud sitting around, so i had to put it back together without it. so tonight i get to take it apart again to replace the stud. shouldn't take but maybe 30 minutes though.
i'm going to use a big a$$ c-clamp and a short section of 1/2" plumbing pipe to press it in
2 other nuts were sort of rough and needed the wrench to get them off the whole way ... should i just go ahead and replace them all while i'm doing it? then i wouldn't have to worry about it again.
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
AeroCoupe
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
