- Jun 20, 2003
- 181
- 0
- 0
Whats going on with cams for the 99+? Who makes em? N/A? how much? how tuff to install? How much to install? What kinda gains?
Mike Bresette said:I'm liking the VT Stage II cams right now. 29rwhp posted.
mike
lopey4.6 said:Comp Cams stage II with their matching springs. 280 rwhp and 296 rwtq with just longtube exaust and a C&L
damien2003gt said:Whats going on with cams for the 99+? Who makes em? N/A? how much? how tuff to install? How much to install? What kinda gains?
Bone Racing said:someone get the lunati cams and test em already
Ok can any one tell me if cams are smog legal I live in MD? Or should I even get cams and just get a Pro-Charger. I would like to have both but 1k and 20rwhp does not add up tp me.Redfire03GT said:Do you have a dyno graph? I want to see if there is any sacrifice in low end torque. Or if the cam has a very peak power band and you mostly only see gains from say... 4k and above. If a pair of cams can give a good over all gain with out hurting low end power and still actually pass the nazi ass california emissions test, then I'm all ears. So far, as it appears, the cam you have gives 20rwhp over my stock cams, which isn't bad at all, although I don't want to sacrifice torque in the process.
nickthegenius said:Also, I came across this tool in a post at Modular Depot. It is supposed to save 3-4 hours of work by letting you do the swap without touching all your accessories and cam chain covers.
You can buy it here: http://www.andersonfordmotorsport.com/new_products/new-46.html#camtool
NasaGT said:That is so SWEET!!!. That has to knock a whole bunch of time off of a cam install. Between that and the spring compressor tool (that you posted in a different thread) a cam/spring upgrade is starting to sound easier and easier. Thanks for posting that nickthegenius!![]()
nickthegenius said:Hey, no problem. Anything to make a job easier! I just wish there was a $30 tool to cut 3-4 hours off of a header install![]()
You'd make a ton of money on that.
