  • SN95 4.6L Mustang Tech
cams off a notch?
  • Thread starter Thread starter blowngt01
  • Start date Start date Oct 7, 2005
blowngt01
  • Oct 7, 2005
cams off a notch? on blown oo GT. HELP PLEASE
My 00 blown gt was just rebuild and will not drive. The car starts and idles but as soon as you put any load on the motor like putting in first gear the car choaks and surges. I have taken it to two tuners and three shops and nothing found. Could the cams be installed incorrectly. Like one tooth off. Please help me. Thanks
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Oct 8, 2005
  • Oct 8, 2005
this could be almost anything.. how is the idle quality?
blowngt01
  • Oct 8, 2005
Well the car has mild comp cams and the idle is pretty much normal. What would the car do if the cams were off a notch on the chain?
Mike97gt
it doe snot
10,633
Oct 8, 2005
  • Oct 8, 2005
does it stay running.. after this surging.. does the car have any power at all.. somtimes you can get a surge from coolant in the plug wells..
blowngt01
  • Oct 8, 2005
The car has been like this for 8 months. I started it today and it starts and idles fine with a little lope but if you put it in gear there is no power, it bogs and chokes. If the car is idleing and you try to rev it up and hold the rpms at say 2500 rpm's it can't stay smooth. It stumbles up and down.
Mike97gt
it doe snot
10,633
Oct 11, 2005
  • Oct 11, 2005
8 MONTHS nobody can fix it.. you need too start by testing the ignition system.,. see what the ignition i doing when this happens.. you are goign too need some scan tool with igntion test funtion.. liek the ford WDS. then test the fuel system.. see what he fuel pressure is doing when this happens.. if both spark and fuel are ok then retime the cams and see what happens
nyuk98gt
1,427
Chesterfield, MO
Oct 17, 2005
  • Oct 17, 2005
blowngt01:
I can't give you a firm answer because, imho, you need to datalog to see what is happening. Without data, it is going to be hard for you or your tuner to pinpoint the issue. The wandering idle could be off-spec cam timing but it could be due to plenty of other stuff, too.
Good luck!
Chris
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
