M mustangpower5 New Member Jun 19, 2006 4 0 0 Dec 23, 2006 #1 Dec 23, 2006 #1 What exactly do i need to do...modify or change on my motor so i could safely have cams stage 2's and run good?
kooldawg6 mine works really well and can take a fair amount Aug 31, 2006 1,679 2 38 Central VA Dec 23, 2006 #2 Dec 23, 2006 #2 Here is Blow By Racing Stage 2 and Stage 3. http://www.blowbyracing.com/bbr-3vbilletstage2.html http://www.blowbyracing.com/bbr-3v-billetstage1.html
07 dmentedstang New Member Oct 23, 2006 6 0 0 se, mi Dec 26, 2006 #3 Dec 26, 2006 #3 comp cams says to change valve springs
07 dmentedstang New Member Oct 23, 2006 6 0 0 se, mi Dec 26, 2006 #4 Dec 26, 2006 #4 comp says to change valve springs
anthony05gt Active Member Mar 18, 2006 1,262 1 37 Maryland Dec 26, 2006 #5 Dec 26, 2006 #5 Definitely upgrade the valve springs, porting and polishing would help greatly. Bottom end will be fine as long as it's getting sufficient fuel. Cams won't be so much of a gain that you'd have to worry about any other internal work.
