Camshaft for 289 A Code
  • Thread starter Thread starter KaraKedi
  • Start date Start date Sep 5, 2008
KaraKedi
83
Istanbul/Turkey
Sep 5, 2008
  • Sep 5, 2008
Hi,
I'm just starting upgrade to my Mustang for more power
What i did:
1) INTAKE MANIFOLD STEALTH DUAL PLANE
2) CARBURETOR 600 CFM 4V W/ ELECTRIC CHOKE (HOLLEY)
3) DISTRIBUTOR READY TO RUN PRO-BILLET 289/302 (MSD)
4) COIL BLASTER 2 (MSD)
5) SPURK PLUG WIRE 8.5 MM (MSD)
6) SPURK PLUG (NGK)
What will i do:
1) HEADERS (TRI-Y)
2) CHAMSHAFT (?)
For this configuration, which camshaft is the best?
Regards
woodsnake
1,352
15
69
Hicksville, NY
Sep 5, 2008
  • Sep 5, 2008
You can put what ever cam in it you want, just keep in mind that anything more than around a .500 inch lift will require an adjustable valve train, and maybe a new torque converter and rear gears as well, to take full advantage of the cam.
If you don't have ready access to a machine shop, I'd recommend staying under .500 lift...
D
D.Hearne
11,730
south louisiana
Sep 5, 2008
  • Sep 5, 2008
Ditto on what woodsnake said. You're looking for what's called an "RV" style grind. The @.050 specs will be in the 200-214* range and lifts no more than about .510 lift. Comp Cams 268H is a good pic, but you may need to run premium fuel with it. Summit Racing sells a cam in their own brand that specs at 204/214 and .448/.472 lift that'll work, Also the next step up may work with the stock heads ( 218/228* .471/.471 lift) Anything more and you'll have the stock pressed in studs pulling loose from the heads.
Z06killinSBF
457
McKinney, TX
Sep 7, 2008
  • Sep 7, 2008
Go download CamQuest (FREE) off of the Comp Cams website. It will tell you a recommended cam for said application.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
R
1974 Datsun 620 pickup / 5.0L HO
  • RJH46
  • Aug 24, 2025
  • Other Auto Tech
Other Auto Tech Aug 24, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
C
Electrical HOLLEY
  • CJsbf
  • Apr 12, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Aug 8, 2024
doctorj357
