Camshaft help
  • Thread starter Thread starter gtcobra302
  • Start date Start date Feb 9, 2006
gtcobra302
118
Centra Florida
Feb 9, 2006
  • Feb 9, 2006
I am running a N/A 89 GT 5 speed. What lift and duration cam does anyone reccomend? Is anyone running B or E cams? What rockers can I use with them? I heard you cant run 1.72's with the E is that true? Who is running anything else then ford racing cams? What lift and duration? I am running an F cam now and I am thinking it is too big, too much lobe seperation for a n/a car. Trick flow intake, 70 mm tbody and egr spacer, 73 mm mass air, 24lbs injectors, regulator, fresh rebuild, cold air intake, k and n filter, msd 6al box, coil, wires cap and rotor, gt40 iron ported and polished heads, equal length shorties. Thanks
TrunkFunk
Banned
Dec 28, 2005
83
A1A - Beach Front Avenue ...
Feb 9, 2006
  • Feb 9, 2006
Since you're running larger valved heads (and I assume stock pistons) you want to run a cam that isn't excessive in lift and duration.
If it was my car I would go with a Trick Flow stage 1 or the tried and true E.
I
IntenseBlue
946
  • Feb 9, 2006
Get a custom cam from Jay Allen, Buddy Rawls or Ed Curtis.
TrunkFunk
Banned
Dec 28, 2005
83
Feb 9, 2006
  • Feb 9, 2006
That's the better option, but sometimes twice the price as the shelf grind.
LordMustangGT
118
Port Orchard, WA
Feb 9, 2006
  • Feb 9, 2006
I'm running the F303 in my bone stock 89. I freakin love it, I don't see why your complaining, i might go a little bigginer. but I love that cam, works great in a computer controled car, and the lope is perfect, idles right at 7-800rpm. and the power band is awsome. just my opinion though,...
vikingpower
656
CWU Ellensburg, WA
Feb 9, 2006
  • Feb 9, 2006
Make sure your valvesprings are appropriate to the cam specs, and if you got stock or stock-spec springs make sure you upgrade them; otherwise you'll just be floating the valves over 3500RPMs
I
IntenseBlue
946
  • Feb 9, 2006
$300-350 is a small price for the horsepower gains of a cam.
Hell, most guys spend that or more on a catback.
thumper460
3,022
Orange Park , Fl
Feb 9, 2006
  • Feb 9, 2006
Keep the F cam and install it at 105 ICL ( 4* advanced)
Keep the 1.72s.... If the rear gears are in the 3.73-4.11's !! IF 3.23s or 3.55 then the B cam and the 1.7's ... ORRrrr..... Put a X cam in!! sell the 1.7s and get the F cam and a set of 1.6's!! ORRrrrrr... spend 350.00 for a custom grind... possibly not go any aster and wonder why this combo costs so much!! LOL
Just me.............................
Thumper
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
