I am running a N/A 89 GT 5 speed. What lift and duration cam does anyone reccomend? Is anyone running B or E cams? What rockers can I use with them? I heard you cant run 1.72's with the E is that true? Who is running anything else then ford racing cams? What lift and duration? I am running an F cam now and I am thinking it is too big, too much lobe seperation for a n/a car. Trick flow intake, 70 mm tbody and egr spacer, 73 mm mass air, 24lbs injectors, regulator, fresh rebuild, cold air intake, k and n filter, msd 6al box, coil, wires cap and rotor, gt40 iron ported and polished heads, equal length shorties. Thanks
