ok guys this is the camshaft that im looking at to throw into my cobra. my question is that the lift on the cam says that it is those numbers with stock rockers. but since the rockers on the cobra are 1.7's what will the lift numbers be with the 1.7's and the other question is what would be the max lift cam that you can put in our cars without doing valve springs. thanks in advance.
Small Block Ford: 1985-93 HO 302, 5.0L (with roller tappet cam), 1994-95 351W (with factory roller cam when used with mass air EFI), hydraulic roller camshafts
Advertised duration: 299 intake/309 exhaust
Duration at .050 in. cam lift: 222 intake/232 exhaust
Gross valve lift: .510 in. intake/.534 exhaust
Lobe separation: 112 degrees
Peak horsepower rpm: 6,000
Peak torque rpm: 2,750
Power range 2500-6000 - Fair to slightly rough idle
