Can a 91 DIS block be converted to a distributor style engine
Red_LX said:
Well, THEORETICALLY you could. But it's not that easy to have the distributor hole bored out to accept the distributor. I suppose he could try if he wanted to.
OR..... you could simply run it off of the front of the motor. You would need some custom brackets made up, and some modifications to the distributor, you could run it either directly or with some form of drive system off of the the front of the cam shaft. I've seen it done of 4 different 4.6L mustangs.
Yes,if you would look you would see that you either have ,a alum. plug that continues to run the oil pump or a CPS(California specs but still run the pump)The blocks were the same machining until 95 when they went to a oil pump that run off of the timing belt.I never seen one that didn't have the dist.hole machined in...
