Problems with out actually losing its alignment? I had a vibration at about 1800 that was there before my recent T5 swap. It is still there but more noticable now. The balancer looks as if it is showing TDC at the proper point. Can the elastomer "dry out" and kill the efectivness of the balancer?
I went a few steps richer which helped but there is still some vibration there. It is evident with the car out of gear just reving the engine, clutch in or out. I have eliminated the drivetrain by coasting down the highway then reving to that RPM.
The cap and rotor look good, the mixture was, but is no longer lean, wires check out on an ohm meter, and plugs are fresh. The firing order is correct and I have seperated 7 and 8 to eliminate cross fire.
I have done a search but most folks don't report the final repair that works.
Thanks
Thanks
