Can a open rear end be converted to a posi?
  • Thread starter Thread starter mike78
  • Start date Start date Mar 18, 2006
M
mike78
80
  • Mar 18, 2006
Just trying to plan my build up.... and I want to use the 8" rear, but want posi, trac-loc, auburn, locker? rear. My car currently is a whon wheel wonder, and in looking for a third member the prices for a whole unit are out of my current reach. So what I am asking is for advice on wheather or not I can buy the guts and put mine together with what I have. It it possible? Thanx, Mike.
muh'stang
If I were rich, I'd make sure all the scoops on my
Sep 26, 2003
277
Quesnel, B.C., Canada
Mar 18, 2006
  • Mar 18, 2006
weld the spider gears...your rear end will be completely locked, no slip. Google it, Im sure you could find more info, I saw some with diagrams even once.
alcino
195
san diego, ca
Mar 18, 2006
  • Mar 18, 2006
Do not weld the spider gears. Yes it is cheap, but you will hate driving the car.
I did the powertrax lock right locker. All you do is remove the spider gears and add the unit in their place. Not that hard to do. They now have available a "extreme traction system" which should dissengage(sp?) a lot smother in the turns with the same straight away locking power.
http://www.powertrax.com/
Dano78
2,633
Vancouver, WA
Mar 19, 2006
  • Mar 19, 2006
I wouldn't weld the spiders either. Save that crap for a demo-derby car or a figure-8 thrasher.
The Powertraxx Lock-rite is certainly the way to go. I put one of these int he front diff of an '87 Ranger and I'll tell ya, it's impressive! I busted one of the front 2 axles and it still was pullin the one good front wheel with the opposite axle broke! Great units!
Another cheaper option, like welding the gears, is dropping in a mini-spool. I'd rather do that than well up the crap. I have a mini-spool in mine and it seems to be ok. Not something I'd drive daily. the mini spool replaces the spider gears just as a Powertraxx Lock-rite does. the Spool will be cheaper but you won't have the benefit of the unlocking Powertraxx for that city driving.
M
mike78
80
  • Mar 19, 2006
Thanx for the info. I think the powertrax is the way I'll go. I have been searching aroung their site and it seems to be a good deal. I just wonder what happens if it does fail...
Blue Thunder
1,003
55
68
Upstate New York.
Mar 19, 2006
  • Mar 19, 2006
Back when I was young, I had a 200sx datsun beater car, and I blew up the stock spiders doing cheesy hole shots at 7k, so I had a buddy weld the carrier solid. Anytime I wanted to slow down, I didnt need to use the brakes, I just swerved back and forth in the road. How handy.
Joeverb
440
  • Mar 24, 2006
Blue Thunder said:
Back when I was young, I had a 200sx datsun beater car, QUOTE]
I called mine the 200 sux.
Ive used the power trax in the front of my jeep and they are pretty reliable. The only problem i had was an occasional sheered crossshaft.
A
90 Fox 4Lug rear convert to 5 Lug
  • adimice
  • Jun 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
limp
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
