  • SN95 4.6L Mustang Tech
can anyone help a stangirl
  • Thread starter Thread starter mustangrl00
  • Start date Start date Jul 1, 2007
  • 3
1 of 3 Next Last
M
mustangrl00
  • Jul 1, 2007
i changed my tps, iac, iat...cleaned the maf...i have an accerlation/loss of power problem...when you step on the gas she wont go....any other ideas?
2000 gt 5 speed...x pipe with cats cold air
SilverBullet00
1,150
Wichita, KS
Jul 1, 2007
  • Jul 1, 2007
Try a new fuel filter and spark plugs. Did this problem start all of the sudden or gradually?
Other things you might want to do-
-Injector cleaner
-Seafoam
-Inspect your COPs
EDGE Motorsport
561
Saleen S281, London, UK
Jul 1, 2007
  • Jul 1, 2007
always worth a go, careful with the fuel though, it stings like a b***h when it gets in your eyes...
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,085
224
Massachusetts
Jul 1, 2007
  • Jul 1, 2007
Run your codes and see if anything is stored
Scorcher2005
883
South Carolina
Jul 1, 2007
  • Jul 1, 2007
I would think any idiot would know to try and attempt to not let fuel drip on them.
But stang girl, when you try and go, does it more like sputter and feel a little powerless? If so, my car started doing the same thing. Some new copper plugs fixed that one. But make sure your coil on plugs are pressed all the way down and the connectors are on good before you change something you may not need to, although it wont hurt.
spitfirees20
38
  • Jul 1, 2007
Exactly, that would really help. Aside from that, I would say new plugs / fuel filter / injector cleaner, although without really knowing what's going on that's throwing a decent amount of money at something that could be anything.
BigChiefSmokem
1,400
Jacksonville, FL
Jul 1, 2007
  • Jul 1, 2007
I kinda had the same problem a while back. New spark plugs and fuel filter fixed the problem. I was due for those to be replaced at that mileage anyway... The car just kinda "forced" me to do it anyway.
propellerhead
1,541
"but what's with the but shots?"
Jul 1, 2007
  • Jul 1, 2007
Drive a V6 for a week.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 1, 2007
  • Jul 1, 2007
As these other guys said change the fuel filter and plugs
If that don't fix it try to get a fuel pressure gauge and monitor the fuel pressure while you get on it. If it drops then you might have a fuel pump or fuel rail pressure sensor issue..
Many time with a fuel pump concern it will run ok at light throttle but stumble right on it's face at WOT
SilverBullet00
1,150
Wichita, KS
Jul 1, 2007
#10
  • Jul 1, 2007
  • #10
In addition, have your intake manifold looked at. I notice you have a 2000, those came with the plastic coolant crossover that is prone to failure. When mine cracked on my 2000, it cracked on the bottom by the thermostat housing and I couldn't see it. It leaked coolant into my #5 spark plug hole and caused it to miss really bad, and it didn't throw a code. So depending on the symptoms you have, you might want to have that looked at.
DuRsT
#11
  • Jul 2, 2007
  • #11
LOL
Turbo92PGT
746
Auburn Washington
Jul 2, 2007
#12
  • Jul 2, 2007
  • #12
I am going through the same thing. Every symptom I can I have read about points my problem to MAF!
I will run with my IAC DISCONNECTED, and the idle hangs at 1200. No air leaks whatsoever!
Driving around normally works ok, it feels down on power for normal driving. But when you get on it the car will hit a certain RPM and completely shut down. The check engine will come on real quick, but then go away and then the car comes back to life.
The throttle body is closing fully and not sticking. When you disconnect the car when the MAF is running the car dies instantly if it is up to normally operating temp. Under norm (closed/open loop - not sure which is which) temp the maf can be disconnected and it will idle good.
The IAC has been changed with numerous known good ones.
I'm going to replace my o2 sensors and fuel filter.
StaffAmerica74
120
Easton, Pa
Jul 2, 2007
#13
  • Jul 2, 2007
  • #13
I have a 93 lincoln mark viii with a DOHC 4.6 and it does teh same exact thing. I put a new fuel filter and new plugs in 2 months for this started doing it so I eliminated them from my thoughts. Then I replaced the fuel pump with a 255 walbro. Replaced the injectors still did it. Replaced IAC (major PITA on my car) and EGR Valve (also major pita), still doing the same thing. If any of you guys figure something out let me know thanks. I think it could be my coil packs so I will try that next.
the98stang
2,408
Clovis, CA
Jul 3, 2007
#14
  • Jul 3, 2007
  • #14
A SCT would be very beneficial so you could datalog the car to find the problem. Or else it could be like finding a need in a haystack....
Mike97gt
it doe snot
10,633
Jul 3, 2007
#15
  • Jul 3, 2007
  • #15
If it runs with the iac disconnected you have a vacuum leak. Air is getting in there somewhere. Keep looking
M
mustangrl00
#16
  • Jul 10, 2007
  • #16
well guys...its the intake manifold....two coils gone...i know im going to get some slack...but i think its time to buy an import since ford doesnt want to take responsiblity for the crappy faulty parts they put on their cars....
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 10, 2007
#17
  • Jul 10, 2007
  • #17
Import cars do not get the warranty honored after it has expired either
COPs are about $49 each I believe.
How do you know they are bad?
What exactly do you mean by "its the intake manifold"?
Rougestang
59
florida
Jul 10, 2007
#18
  • Jul 10, 2007
  • #18
If you want to sell your soul..... No reason for it though, I'd much rather take pride in pushing my Ford than drive any of those japanese crap cars that people buy because their "good on gas". Either that or switch to chevy.
spitfirees20
38
#19
  • Jul 10, 2007
  • #19
Nah, it's cool, get an import, they are good on gas Just don't be surprised when you put the pedal to the floor, go nowhere, and miss your stang... everyday.
LI98GTStang
1,715
L.I., NY
Jul 10, 2007
#20
  • Jul 10, 2007
  • #20
Did the all plastic intake manifold crack, leaking radiator fluid onto the coils, causing them to get shorted/work poorly? Very common problem. It can be fixed by replacing the coils and PI intake (with aluminum crossover) for <500, but that sucks anyway you slice it.
The settlement helped quite a lot of people, but IMO, Ford should have gone all the way with this quality issue and covered all, no matter when they had the issue. I don't blame you for moving over to imports with the way Ford handled this quality issue, (if this is what happened to you of course)
  • 3
1 of 3 Next Last
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
squeak93
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
L
Drivetrain 2000 GT High Idle - Pulling Out Hair - Help
  • lleonard1185
  • Jan 18, 2025
SN95 4.6L Mustang Tech Jun 4, 2025
Leo090
L
