Can coolant come from...
  • Thread starter Thread starter roush 97
  • Start date Start date Mar 21, 2004
roush 97
86
Illinois
Mar 21, 2004
  • Mar 21, 2004
The timing chain cover? I ask because I'm still leaking coolant. Ever since I flushed my radiator last fall I've had coolant leaks. I thought it was the weep hole on the water pump so I replaced that. It looked as though the gasket was pretty deteriorated too so I'm wondering about the gasket on the cover. I believe it's also leaking out of the coolant resevoir too.
squeeeg
1,905
Michigan
Mar 21, 2004
  • Mar 21, 2004
I can't see it leaking from the timing chain cover but the water pump could be leaking in the water pump gasket. You may want to look closer to pinpoint it.
roush 97
86
Illinois
Mar 21, 2004
  • Mar 21, 2004
I just changed that out. I guess it's possible that it may be leaking again.
SAYNOTORICE
152
Massachusetts
Mar 21, 2004
  • Mar 21, 2004
definitely possible to be leaking from timing chain cover, mine was deteriorated and it was leaking fluid badly, so dont rule that out
roush 97
86
Illinois
Mar 21, 2004
  • Mar 21, 2004
Well, it's gotta pretty much be narrowed down to that. I'm sure it's not the water pump since I replaced it. It's gasket was pretty bad. I'm sure it's not the hoses, but I need to replace them anyways.
trbkrb
1,976
Houston, TX
Mar 21, 2004
  • Mar 21, 2004
Yes, mine leaks in the valley by the PS pump. Not a lot, so I just keep it topped off, but that valley is always full of green water. The water passages run right through the timing chain cover.
roush 97
86
Illinois
Mar 21, 2004
  • Mar 21, 2004
I wouldn't worry about it since as long as I top it off every once in a while, but it drips all over the garage floor so I kind of want too fix it.
Carney Woods
191
Montreal, Quebec
Mar 22, 2004
  • Mar 22, 2004
I had a similar problem and it stopped when I repaced the timing chain I put a new gasket on the water pump with a lot of gasket sealer at the same time as the new cover gasket. No problems since.
StangGT_conv98
9
EP, Texas
Mar 22, 2004
  • Mar 22, 2004
Intake Manifold
I had a problem like that to where i couldn't find the leak and i thought that it was the water pump, but then i check it and everything was fine. After checking for any other leakage i didn't find anything untill i ended up cleaning my engine and saw that i was leaking from the Intake Manifold. WHICH REALLY sucks. those things are made of plastic. the leakage was on the from passage way from the therm. to the first fuel injector. i could see it leak as i kept wiping it off. so u might want to check ur manifold. GOOD luck to ya!
roush 97
86
Illinois
Mar 22, 2004
#10
  • Mar 22, 2004
  • #10
Thanks for the info guys, I'll check it out some more.
J
jerry beach
2,671
Ocala,FL
Mar 22, 2004
#11
  • Mar 22, 2004
  • #11
cardudeusa, here on stangnet told me about the timing chain covers leaking. I have a leak coming out of the back side of the cover and pooling on top of the cover right below the thermostat housing. There is a small hole in the back of the cover on both sides right there. You need a mirror to see it. What he did is JB weld that hole shut, just make sure you clean the area up real good before hand and you will be fine. Its an easy fix, but I have not done mine. Hopefully its not the lower intake. I have never actually seen mine leak, but I know its coming from there.
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
