can gears improve gas mileage and acceleration?
Max Power said:
Am I the only guy that loves the sound of my engine at 3500rpms? If you get decent heads, a lumy cam and decent exhaust, it's music to my ears.
One of the first things I did, in 1982 after I bought my '68 at age 16, was to dual it out with glass-packs. At first, the blarring sound was cool, but after about about a year of listing to it, I ditched them for turbo mufflers and that's all I've had since.
I like a nice rumble, but loud is annoying if you're traveling more than 30 miles, or if the car is your daily transportation, which my '68 was for 7 consecutive years.
www.ultrastang.com
ultrastang said:
If you are running a C-4, C-6 automatic, or Top-Loader 3- or 4-speed manual transmission (all 1:1 in high gear), then you are greatly limiting the capability your car has in both performance and economy.
The best choice is to run a lower gear ~3.25-3.70:1 in conjunction with an overdrive transmission, such as an AOD or T-5 manual 5-speed (typically .68:1 in overdrive).
The overdrive will allow you to take advantage of off-the-line acceleration with a lower rear end gear, but at cruising speeds, the engine RPMs will drop drastically once the transmisssion goes into overdrive.
As an example, if you had a 26" tall tire, 3.00:1 rear end ratio, and non-overdriven transmission, your engine RPMs at 60 MPH would be ~2,326 RPMs. Given this very same senario, except coupled to an overdrive transmission, your cruising RPMs at 60 MPH would be 1,582 RPMs --744 RPM drop.
A T-5, in overdrive, coupled to a 3.50:1 rear end ratio would cause the engine to "see" the rear end ratio as being 2.38:1 (3.50 x .68 = 2.38:1). Even though the rear ratio may be 3.50:1, in overdrive, the engine thinks the rear ratio is 2.38:1 --That's even higher than a stock 3.00:1 ratio with no overdrive, so you would actually get better mileage with the 3.50s over the 3.00:1s, and still have much more accelleration in 1st - 4th gears with a T-5, or 1st - 3rd with an AOD.
http://www.ultrastang.com/Rearinfo.asp?Page_ID=3
I already rebuilt my C4 so i am stuck with it for a while
Max Power said:
All diffs are third members. There are diffs with integral carriers, and diffs with removable carriers. It takes special tools and a knowledge of how to set gear patterns. It's not for a novice.
What gears do you have now? I am willing to bet that they are real close to 3:00 to 1.
I have changed out gears before on the kind of rear end where there is an inspection plate, but not like the one on my 68. i didn't think it was that difficult, a little time consuming but not to hard. so how hard is it to change my stangs compared to the other style?
I am not sure what gears i have right now, it is a stock 68 rear end. i will check the tag later and post it.
If your '68 came stock with a C4 automatic, it's very likely your ratio will be 2.79:1, just like my '68 was.
http://www.ultrastang.com/Rearinfo.asp?Page_ID=5
I can attest to the effect of high gearing - my 35-year-old 302-2v with the original carb and a 2.79 rear with a new TKO600 tranny with a .64 final gear got over 20mpg, probably close to 25mpg, on a recent 200mpg round trip I made. And this was in 90 degree weather.
with a 2.79 rear and the .64 final drive, you just basically fall into 5th gear and lope along on the freeway. Not a bad sensation, actually . . .
