Can I cut my springs?
i cut my springs, ride quality is ok..could be better. for 100 bucks i was like what the hell.. im pretty satisfied, looks good, but i will be investing in some aftermarket springs very shortly, when i start doing othre suspension mods.
cut em i cut mine a year ago i know people with springs they bought and put in and mine rides smoother and it looks good it doesnt hurt the ride quality much just take a little out at a time until u like the how they sit then put em in how they came out
Go with H&R Super Sports if you are looking for around a 1.75" drop.
TireRack.com has them for like $218 a set.
Here is mine:
Cut my springs a month ago, rides like stock and looks 100 times better. Only thing you lose when cutting your springs is suspension travel (you can't lower your car 2" without scraping everywhere), ride quality will be exactly the same. (factory springs have a linear rate)
All these guys saying cutting springs is bad don't know $hit. I have replied to these post plenty of times. Let me just sum it up for you.
You can cut your springs with out any adverse affects, IF you don't go crazy. The typical max amount is 1 coil. That would yield you a solid 1" drop. You can go more, but you will start to have some problems.
Cutting your springs will INCREASE the overall spring rate. If the spring has a linear rate of 450 lbs/inch with 8 coils, then each coil in the spring has a rate of 450*8 = 3600 lbs/inch. If you cut off 1 coil the new spring rate will be 3600/7 = 514 lbs/inch. That will give you a nice drop while stiffing the ride up just a little. Cut off 2 coils then you have 3600/6 = 600 lbs/inch, and that is getting pretty stiff.
You also lose suspension tavel when cutting springs. What happens is that you run a great chance of getting coil bind (the coils on the spring hit each other and it does not act like a spring any more). Aftermarket springs are designed so that even with the shorter spring the overall travel of the spring is better, and thus not have probelms with coil bind.
I have had my front springs with one coil cut off for over a year with out any probelms. It rides just like stock. I also have 1/2 a coil off the rears with no probglems. Actually, I had some FMS C springs at one time and the directions actually tell you that you can cut them if needed, and that is straight from Ford.
