Can I install a 94 t5 in my 87 coupe
  • Thread starter Thread starter voodoo
  • Start date Start date Feb 11, 2009
voodoo
102
Pensacola, Fl
Feb 11, 2009
  • Feb 11, 2009
i have an 87 coupe with a t5 and i would like to put my D&D Performance built t5 out of my old 94 in it. What all do I need to do it or will it just bolt in ?
KamiKaziDK
555
Mesa, Az
Feb 11, 2009
  • Feb 11, 2009
As I recall....the 94-95 input shaft is about 3/4" longer and the bellhousings are different. So if you swap out the input shaft and bellhousing.....I think that's all you need to do??
90topdown
138
Philadelphia, PA
Feb 11, 2009
  • Feb 11, 2009
^^^^^^^ I have a converted 95 t-5 in my 90. No problems.
All you need is the foxbody input shaft and foxbody bellhousing
Hickfied
413
Morganton, NC
Feb 11, 2009
  • Feb 11, 2009
Or you can use the SN95 bellhousing and call it done.
voodoo
102
Pensacola, Fl
Feb 11, 2009
  • Feb 11, 2009
so i can leave the bell housing that is in my car and use the input shaft that is in my current t5 and its a done deal ? Sweet I love that D&D t5
90topdown
138
Philadelphia, PA
Feb 11, 2009
  • Feb 11, 2009
You can do that but you may have to trim the shifter opening in the floor pan as it will now sit 3/4" further back from the engine because of the longer bell housing.
voodoo
102
Pensacola, Fl
Feb 11, 2009
  • Feb 11, 2009
what i meant to say was that i can use my current 87 bell housing and take the input shaft from my current 87 t5 and put that input shaft in my 94 t5 and call it a done deal. lol
voodoo
102
Pensacola, Fl
Feb 11, 2009
  • Feb 11, 2009
how hard is it to swap out the input shaft ?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 11, 2009
  • Feb 11, 2009
See TTC: Product Literature to download a FREE service manual for T5 or Tremec 3550/TKO
You will need the Adobe Acrobat viewer which is also a free download – Adobe - Adobe Reader download - All versions
http://www.hanlonmotorsports.com/ also has a video on how to rebuild your T5 or Tremec. It costs about $20, and is worth every penny of it.
V
v8only
2,378
22
49
Feb 12, 2009
#10
  • Feb 12, 2009
  • #10
swapping the input is simple.
unbolt the 4 bolts to the retainer, twist and pull the input out. put the bearings from the inside of the shaft to the new shaft. use wheel bearing grease on the inside to hold the bearings in place while you're doing this.
put the new shaft on and then pull the bearing sleeve out of the bearing retainer. ditch the shim that's in there, bolt it all back together and measure the in and out play. Then take more shims, and measure it perfect. For a broken in t5, use 2 thousands preload. Put the proper shims in, silicon the bearing retainer and you're good.
hanlonmotorsports or astroperformance should be able to help you with the shims.
the 87 input won't work in a 94 trans...you'll need a 91-93 input shaft...different gear ratios..you'll nuke your trans if you use the 87 input
voodoo
102
Pensacola, Fl
Feb 12, 2009
#11
  • Feb 12, 2009
  • #11
i bet I can pick up a new imput shaft fairly cheap. If you wouldn't have told me my 1500 dollar tranny would be wasted. Thanks man
voodoo
102
Pensacola, Fl
Feb 12, 2009
#12
  • Feb 12, 2009
  • #12
Hey thanks for the free manual download too jrichker that is nice.
V
v8only
2,378
22
49
Feb 12, 2009
#13
  • Feb 12, 2009
  • #13
astroperformance has them listed on their site. you can also find them used from time to time. If you get a new one, don't forget to pick up a new bearing too. It'll either have to be pressed on or hammered on.
I use old bearing races and a socket to tap mine on. You could likely get creative..just be sure to use a socket that is no bigger in diameter to the bearings inner race.
if you're an ebay person, list up the 94/95 input shaft and your old 87 input for sale. The money will offset the cost of the new one.
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
