Can I re-use stock headblots?
I wouldn't take the risk. Especially since a new set only costs 30-40 bucks! You know that the constant heat and cold, not to mention the torque, stretches them out as they get older. You can reuse them, but for the price of new bolts, DIRTFT! :nice:
I reused my head bolts when i replaced my headgaskets, and boy, what a mistake, i weknt through that pair of gaskets in about a month, blew them right out. spend the little bit of money and do it right. plus i wouldnt want to take a chance and break it off in the block.
The older Mustangs didnt use torque-to-yeild but a lot of people put them in. Ive reused stock head bolts on a friends car before but never torque to yeild. You can tell the difference in the size and head of the bolt. I only reused the stock ones because it was a Sunday night and the next monday was a holiday and we didnt want to wait in PA for two more days. Torqued them to spec and drove it home. He checked the torque on them several times and hes been driving with them ever since. No problems to date and its going on a year. He drives it a lot too but doesnt drive it hard. Long story short if you have the cash might as well get ARP equipment. The better quality parts you use in the begining the less headaches youll have in the end.
If they are torque-to-yield bolts - no, you can't re-use them. If they aren't - then they can be re-used IF they haven't been over-torqued and yielded.
The only way to be certain usually is to simply replace them with ARP standard high tensile strength fasteners.
That's for HEADBOLTS. HEABLOTS should never be re-used under any circumstances. :)
