If you put your axles in a fox body rear end, you would be gaining nothing. Your wheels will still be in the same spot they are now. You would actually be putting more stress on the snout of your axles because the hub will stick out farther from the axle tube than it does with a 94-98 housing. I'm really not even sure if it would work, because your caliper is going to bolt on to your backing plate, and the rotor will be pushed out about .5" from where it needs to be because the axles in a sn95 are longer than a fox body.
