Can I use BLACK RTV......
my dad yelled at me for putting on red rtv onto my tstat when i was going to put it in. he said you need to use something that always stays sticky and never drys. maybe ill find out soon if i look what it is....
RC, about your leak. Ive had a simlar issue, and its because of the crappy typhoon lower intake. If you line up the thermo housing on it, with the bolts in, i can see how the stock thermo housing overhangs the bottom of the intake a bit. That spot has leaked since ive had the intake, until this winter when i put the thermo stat housing on and let it dry for days.
BTW, i use black..
I just went outside and looked at my chrome neck since my motor is apart and connected it to the intake. I can see a small gap in between both :mad:
I have the same problem with it being warped and its at the bottom bolt that I said I had the problems with it being loose. The neck is warped right at that corner where the bootom hole is. It's just bent in that corner a small amount, WTF? I will try and have it resurfaced at a local shop and see what happens. :nonono:
