can someone help me find this part?
SMRcalidiv said:
i need the plug on stock headlight harness, mine got a little melted. delk told me 100 for the harness so i thought id see if you guys knew of anyone maybe parting out a stang, or another option, thanks.
you can buy a headlamp connector repair kit from any Ford dealer. comes wth the hardshell connector, @6" of wire, connectors and shrink tube(this should be soldered) we have them in stock, @$16.00 + shipping. the Ford part # is 1U2Z-14S411-JA
If you plan to continue using high wattage bulbs or even if you don't. I'd say get a heavy duty relay harness. I've been using them on all my cars for several years now and running high wattage bulbs. It plugs into one of the stock bulb plugs (so you probably wouldn't have to replace the melted one), and runs directly off the battery, using the stock wiring only to switch the relays...
