Ok im rebuilding a shortblock I got from a freind. Right now its down to a bare block. I need to know all the gaskets I will need to put it back together. I also took my transmission off and will be throwing in a nice clutch so if you can think of any parts I should need lemme know. This is what I came up with:
Intake Manifold gasket- Felpro 1250
Head Gaskets - Felpro 8548 pt 2
Rear Main Seal
Front Crank Seal
Timing Cover Gasket
Water Pump gasket
Felpro 1 peice oil pan gasket, rubber ,(Part number ???)
Freeze plugs
Timing Chain
Cam Bearings
Crank bearings
Rings
Oil Pump
Header Gaskets (Part Number??)
Gasket for lower/upper cobra manifold.
AutoLite 24's
Oil and Filter
AntiFreeze
Transmission Fluid- Mercon/Dextron III
Throw out bearing
Pilot Bearing(roller)
Adjustable Quadrant/firewall adjuster
Joe's Trickflow Heads/Pushrods/Rockers
Dereks ARP main bolts and head bolts
Dereks Centerforce stage II clutch
Machine my flywheel
Is that all I need to reinstall my tranny/ add a set of heads to my car and rebuild my shortblock? Can you think of anything else?
Heres soem pics
Here what alot of weight reduction looks like
My room/storage room
More weight reduction
Theirs where everything went!
I went a lil crazy on the weight reduction here.
Rear Main Seal
Front Crank Seal
Timing Cover Gasket
Water Pump gasket
Freeze plugs
Timing Chain
Cam Bearings
Crank bearings
Rings
Oil Pump
AutoLite 24's
Oil and Filter
AntiFreeze
Throw out bearing
Machine my flywheel
Heres soem pics
