can u really delete ac without a kit???
shadow9055
26
i saw in old posts a routing with no ac delete kit or moving the power steering pump up. also, i found one where parrish50 says he did this and with aftermarket pulleys it doesn't work, but with the stock pulleys it does. can anyone tell me if this is ok or not, or if it works.. i would love to do that instead of moving things up, i love how clean it would look with nothing there..
I did it with my 93 coupe with underdrive pulleys. I was running a shorter belt bypassing the smog. Then I removed the a/c compressor completely. Just had to run an even shorter belt. No, I dont remember the size. It was a trial and error of a couple of runs to the parts store. You can start by taking a piece of rope and run it around (with proper routing as it will be different) and cutting it to the guesstimate length. Alot of ppl say you need a reverse water pump for it to work but I did it without one and never had an over heating problem. Even in the multiple 100 degree days we have here in North Texas. Hope this helps.
Z
thank u so much man. i wasn't sure if it would work. it looks like the belts would rub. thats two guys on here that say it works so. im going for it. again thanks. i don't get why u would need a reverse water pump. but i read a few posts here and there about that.
I think the reverse water pump is under the assumption that it will be turning the wrong way which isnt the case. If I remember right the belt was really close but I could still get an index finger in there. Good Luck.
Z
ya, i went out and looked at it today after reading ur post. it looks like it will be fine. when u look at those diagrams it looks impossible when u look at the actual fn car. its looks perfect. i knew reading was a waste of time..... thanks again man. im gonna try it sunday.
http://www.fordmuscle.com/archives/2000/02/quicktips/beltrouting.jpg
You might find this link helpful. These are belt lengths with underdrive pulleys. Although this shows the power steering being bypassed along with the smog, it gives you an idea of where to start on the belt length. Remember, their is little to no parasitic drag from the a/c compressor when its turned off, so you will only be saving weight.
just wanted to say i got it done yesterday, and was ready to lose my mind. i had one belt that fit on easily and one that just wouldn't go on. but man it was close. so with the easy belt the tensioner went all the way down. therefore just barely rubbing the lower belt.. ............. so after walking away and thinking i took the whole tensioner off and just barely was able to put the half inch smaller belt on. put the tensioner back on and i have a half inch of clearance. no more sqeaking when i start it and she feels a little quicker too. so, now im wondering if i should put underdrive pulleys on too... man does it look so much better under the hood now.
Be aware that the belt will stretch over time, so even if there is clearance now, in a few thousand miles the belt could start rubbing.
It's why many guys opt to buy the $40 ford racing a/c delete kit instead. Hard to do it without the kit and stop the belt from rubbing
I also took my ac an smog off a cpl off days ago, i didnt buy anything but a new belt, its a 73inch belt works perfect, just undo the alt an u can you that as levrage to tighen the belt, i pulled the alt over an put the bolt in on the other side of where it mounts its temp till i can make a braket that will bolt to the alt an the stock mount, but works great no slipping an works great, ill try an get a pic its hard to explain what i did, pm me if you need help with it
